WD45 Ignition Timing
John_B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John_B Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Ignition Timing
    Posted: 17 Mar 2011 at 4:44pm
What works best for timing with the electronic ignition conversions. The AC manual says to use the tDC mark on flywheel to static time when points just open. What works best for electronic ignition? Can one use a timing light aimed at the flywheel marks at idle?
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2011 at 5:58pm
Timing light should fire on the F mark at high idle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2011 at 7:53pm
I time mine by ear from advice from an old well respected AC mechanic.  Open the throttle to full open and allow to run for about 10 seconds. Snap the throttle shut and you should get one fairly loud and one soft pop from the exhaust.  That works on distributor type ignitions, but not on magnetoes.
