WD45 Help |
Post Reply |
zach
Bronze Level Joined: 03 Jul 2012 Location: Jasper, IN Points: 3 |
Posted: 09 Oct 2017 at 2:21pm |
Got a WD45. changed it over to 12 volt, electronic ignition, and rebuilt the carburetor, and got it running. Tractor seems to be using a lot of fuel and burning really hot. At night the muffler and exhaust manifold will be glowing red hot, and it is heating up the hood and bubbling the paint? anyone else had an issue with this? any help would be appreciated.
JimD
Orange Level Joined: 11 Sep 2009 Location: Mounds, OK Points: 2100 |
Timing or exhaust valves not closing, or exhaust restriction. Most likely timing since you were in there with the conversion.
Owner of OKtractor.com PM for an instant response on parts. Open M-F 9-6 Central.
We have new and used parts. 877-378-6543 |
Ed (Ont)
Orange Level Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1256 |
Late timing for sure. Take the the inspection plate off under clutch. Get a timing light out and time it for the "F" mark. So with the engine wide open the F has to be straight down.
A bit of a guessing game as there is not a second reference to go by. Straight down to the best of your ability. That "F" is 30 degrees. F for fire. There is another reference mark just a line if I remember correctly - that is zero. Hope that helps.
Ed (Ont)
Wondering if you had any luck resolving this issue?
zach
yes I did. timing was way off. running like a top now! thank you
Post Reply | |
