WD45 Hand Clutch Lever - Bushing? |
Jeff(WD45-SATX-TN)
Joined: 13 Sep 2009 Location: Sewanee, TN Points: 443 |
Topic: WD45 Hand Clutch Lever - Bushing?Posted: 22 Nov 2010 at 10:20am |
I am looking for the bushings that go in the hand clutch lever. Does anyone know part numbers, source? I think there are two.
Thanks
Jeff Edited by Jeff(WD45-SATX-TN) - 22 Nov 2010 at 10:40am |
1954 WD45 NF "Iron Tater"
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
Posted: 22 Nov 2010 at 1:29pm |
The bushing are 7/8" ID and 1" OD. I found them at our local electric repair spot. They fix and repair a lot of electric motors. Otherwise Steiner Tractors has them I think
norm[ind]
Joined: 29 Oct 2010 Location: bourbon,ind Points: 2992 |
Posted: 22 Nov 2010 at 8:11pm |
be sure to check the pin it pivots on from the tranny??????seen them worse than lever
Jeff(WD45-SATX-TN)
Posted: 22 Nov 2010 at 8:21pm |
Hey Norm.
The pin on mine is not in the greatest shape, but usable enough for now. Thought the bushings would get most of the slop out. What is the procedure for changing that pin? Are they available?
daveingreenbay
Joined: 09 Oct 2009 Location: Green Bay Points: 281 |
Posted: 22 Nov 2010 at 9:01pm |
Have replaced several pins. Remove the transmission cover and drive the old pin from the inside out. Remove the right side frame. Put the new pin in the freezer to shrink it down and then drive it in the same depth as the old one. With new hand clutch bushings you are back to square one. HTH
Skyhighballoon(MO)
Joined: 11 Sep 2009 Location: Pilot Grove, MO Points: 3115 |
Posted: 22 Nov 2010 at 11:13pm |
Jeff - I bought mine at McMaster-Carr on-line. Part number I order was: 2868T192 for a 7/8 ID/1" OD bronze sleeve bearing 1.5 inches long. I think my plan is to cut them in half and insert half from each end of the pivot. They were only $2.68 each. I have yet to put mine in. I also ordered bushing for my foot clutch pedal as it was even worse. It doesn't have bushings so I bought a 1 1/8 drill bit and drilled out the foot clutch and put bushings in. Shaft was worn on it too but it was MUCH better after being bushed. Mike
1968 Gleaner EIII w 10' & 330 1969 180 gas 1965 D17 S-IV gas 1963 D17 S-III gas 1956 WD45 gas NF PS 1956 All-Crop 66 Big Bin 303 wire baler, 716H, 712H mowers |
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29819 |
Posted: 23 Nov 2010 at 7:35am |
I also added a grease zerk after installing a new pin and bushing.
Wink I am a Russian Bot |
Gerald J.
Posted: 23 Nov 2010 at 9:37am |
Baum Hydraulics at Omaha (www.baumhydraulics.com) is another source of bronze bushings. 7/8 x 1 x 1-1/2 is their number CB14-1612
Gerald J. |
