WD45 Front Loader Lift Capacity?
dpehrson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpehrson Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Front Loader Lift Capacity?
    Posted: 09 Jun 2012 at 9:32am
New to the forum and just purchased a WD45 w/ frontend loader. What is a realistic weight limitation for the bucket. Will it lift 1000 pounds?
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2012 at 9:49am
I would say yes, but will be hard to steer and unless weight added, very light/poor traction.
Edited by Bob D. (La) - 09 Jun 2012 at 9:50am
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpehrson Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2012 at 10:29am
Thanks Bob D. for the reply...Just need to snag a generator that weighs about 1000 pounds and relocate it. Will be going very slow. Just wanted ask first before attempting...
dustinmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2012 at 10:35am
I had one on a wd and honestly it would pick up 1500 but that was it. I know because I was picking up 14 inch h pile at seventy some pounds per foot , just be careful when you let it down because with a heavy load she drops quick
jjpetrich View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjpetrich Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2012 at 10:39am
Lifted up a 2100 lbs bull up to the neck before a hose blew.
On the farm wd,wd45,180,200,7020,8010,8050,f,L2,2 b engines
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2012 at 10:53am
WD 90 loader was listed as 1500 lb lift capacity. and came with a 9 CF bucket. which is about 1100 lbs of manure. Mine with a set of wheel wieghts and a cab has no problem with 1000 lbs. it will get hard to steer. Rember to always carry your load as low as possable. f I need to move anything heavy more than just a few feet I lift it up back the trailer under and move it on the trailer.
Edited by Dakota Dave - 09 Jun 2012 at 10:56am
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2012 at 10:57am
cab?
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2012 at 11:21am
Automatic Equipment Manufacturing company, Located in Pender Nebraska made this unaversial cab in the 1950's . I've seen them on several differant tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2012 at 12:27pm
almost looks like a grain box of an old gleaner. I like it. bet it's a lot better than a heat houser in the winter
German Shepherd dad
#WD234847
#WD88193
is that loader modified or bent?
German Shepherd dad
#WD234847
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2012 at 1:55pm
The loader is straight . But it has quite a bit of reinforcment welded to it.  It is a lot better than a heat houser. the warm air from the engine blows bak and I don't need any more than normal street clothes. In the summer the canvas fwd part and rear door come off and the windows open.
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2012 at 2:14pm
It'll lift 1000 lbs easily.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2012 at 2:20pm
Back when my pump was turned up a bit, I could push the rims to the ground with 35PSI in the front tires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpehrson Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2012 at 4:27am
Thanks a million to all who have replied on the loader capacity post. I look forward to many good years in sharing the retirement years with this old girl doing the lifting by my side...
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2012 at 6:19am
Mine will lift enough to turn it over.Ben there,    MACK
