WD45 cream paint and decal question
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Topic: WD45 cream paint and decal question
    Posted: 12 Mar 2011 at 5:45pm
I am painting the hubs on my WD45 the D17 cream color since as far as I can remember they've been that way and I like the "newer" style look of it and I was where I can get the paint? TSC doesn't seem to keep it in stock. I'd like to use the restoration series if possible.
Also what are your opinions on Mylar vs Vinyl Cut  decals other than price? The vinyl cut are more expensive but sound like they're easier to apply and are the same as original.
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Ira View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ira Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2011 at 7:20pm
I have been using a Rustoleum almond paint on mine and liked the results.Usually can be found in Walmart or Ace Hardware.
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2011 at 7:21pm
 I just bought cream paint for my 7060 wheels from agco.
Zyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zyta Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2011 at 7:29pm
Agco carries what your looking for.
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2011 at 7:40pm
Here is where I get my PO#1 and I like it, they have all the colors.
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 5:42am
Lonnie-This paint from Tractorpartsasap...is it a single part paint with no hardener?  How is coverage?  Would 1 gallon do a D19 tractor?
Thanks in advance,
Terry
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
Chris (swIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris (swIA) Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 9:06am
I would avoid AGCO for paint if possible. The last spray can of PO #1 cost me $20. The quality is good, but not that good.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 9:55pm
Chris, with paint you get what you pay for.  I used AGCO paint on my D17.  Pricey?  Yes.  But it is easy to work with and holds up very well.  Sure, you can buy a gallon of paint from TSC for $25, but your tractor will be pink in a few years.
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 10:01pm
Have you ever thought of using IH white? Its more of a cream color. It looks pretty close too.
D17 owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17 owner Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 10:05pm
I would also go with agco paint. I know some think it is to much. I think if you all putting all that time into it sray somthing that is going to last. BUT with that said I spent 300 bucks two years ago to sand blast my meryers snow plow. I bought ace primer and paint. I was wanting to get it done. I dont think it is dry yet NEVER AGIAN! Eric
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 10:06pm
Terry, I add hardener to the paint when I use it. I used about 2 1/2 quarts on my WF.
Toscani NE SD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toscani NE SD Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2011 at 5:30am
cream hubs on a 45,don't do it,u might as well paint em green
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2011 at 6:40am
shame on you for mentioning 'the color' lol jk. dealers painted them cream for years to update their stock with the d series. davarn here in pewamo did that to several. some farmers would even have it done. they will be cream. alos, i found 'antique white' from tsc is almost an exact match.
German Shepherd dad
#WD234847
#WD88193
D17JIM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17JIM Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2011 at 12:41pm
It's his tractor to paint as he wishes.  I like the looks of a 45 painted  that way also.
I'd NEVER paint it green. BUT, it's his tractor !
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2011 at 8:17am
With this paint from AllStates or Valubilt, does a guy need thinner?  Is it just some standard enamel thinner?
Thanks in advance,
Terry
