wd45 cooling problems
 Post Reply Post Reply Page  <123
hunter321 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2023 at 10:32am
If the wd and wd45 have the same brake rod I could replace it easy
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2023 at 1:10pm
If they are not the same where can I get them
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2023 at 1:37pm
same according to parts book
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2023 at 9:13pm
All of the sudden the tractor won't start and it turns over very sluggish
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2023 at 9:17pm
Weak battery? Put it on a charger .
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2023 at 8:20am
The battery is fully charged
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2023 at 10:20am
After a good battery, check the ground. I had intermittent trouble with one that had corrosion in the cable inside the factory insulation.   Finally it pulled apart as I was cleaning the end again. The cable was on the mid 80's tractor when I got it 10+ years ago. Cable looked very good from the outside.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2023 at 10:34am
I will clean all the connections.
So the bad ground caused the tractor to be sluggish and not start
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2023 at 8:18am
I cleaned the connection but it still won't start. I have no idea what is wrong I just had it running
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2023 at 9:04am
as mentioned, the two most common problems are the battery has not been charging and now needs to be charged up.... or the cables / battery clamps are corroded... Look inside the clamp on the battery cable.. Sometimes you get a black oxide coating that insulates the connection.. Need sand paper or wire brush to get it SHINNY... Look at the battery terminal also... wire brush till BRIGHT.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2023 at 9:09am
ok i will check that when i get home.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2023 at 8:39am
i cleaned the battery terminals and it helped with the sluggish turn over but i think the fuel system might be air locked
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2023 at 9:34am
is there a way to lubricate the starter and flywheel so it might work better
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2023 at 6:17pm
I've tried everything you told me to and it still won't start for some reason
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2023 at 6:54pm
It started and the pully plug blew out
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2023 at 7:23pm
So, put the belt pulley plug back in the hole and get a large 1/2" flatwasher to stick under one of the three bolts near the belt pulley hole to hold the plug so it cannot fall out again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2023 at 7:56am
Is there supposed to be hydraulic fluid behind the plug
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2023 at 9:49am
It leaked a lot of hydraulic fluid from the belt pulley plug
Is that bad that fluid came out of there
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2023 at 9:54am
On the left side of the tractor ahead of the battery box is a short dipstick. This is for the hydraulic pump. Refill it with hydraulic oil. This oil is what came out of the belt pulley hole.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2023 at 10:31am
Ok so when the plug comes out it emptys the hydraulic pump reservoir
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2023 at 11:02am
It doesn't "EMPTY" it. It loses a quart or two out of a 6 quart compartment. Refill until the dipstick says it's full.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunter321 Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2023 at 11:03am
Ok I will.
So it is normal for it to have fluid in it
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2023 at 11:51am
YES. If you had a belt pulley, the oil is what lubricates the gears and bearings.
