WD45 Clutch pedal assem.
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Clutch pedal assem.
    Posted: 09 Mar 2011 at 9:46pm
I'm putting mine back together and I'm not really sure on one thing....the clutch rod had a bracket bolted to the frame rail with a spring holding the pedal forward taking the slack out of the pedal....doesnt seem right....seems to me it would wear on the throwout bearing....what is the correct way to take the slop out of the pedal?
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2011 at 6:23am
There is no spring....throw it away and adjust freeplay to 2 to 3 inches at the clutch pedal pad by changing clutch rod length OR adjusting pressure plate finger height.
This page was generated in 0.225 seconds.
