wd45 cam
hardscrable View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hardscrable Quote  Post ReplyReply Direct Link To This Post Topic: wd45 cam
    Posted: 23 May 2011 at 1:27pm
A buddy of mine picked up a used cam for a wd 45 at the LeSuer swap meet in minn.  Got the bad one out (thanks to Dr Allis) the band around the push rods worked great, but the 2 cams are different.  The original has a disc on the front that the timing gear conects to with 3 bolts but the replacment doesnt.  Replacement is threaded in the center.  Would the disc on the bad pull off?  I put a puller on and some pressure but would'nt budge.  Looks as if I need a different cam, any sugestions on where to track down a new or used would be appreciated.
Thanks Hardscrable
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 1:42pm
There were different cams used on different serial number engines.
I don't think that piece comes off.
What is the casting number on the cam you want to replace?
Post Options Post Options   Thanks (0) Thanks(0)   Quote hardscrable Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 4:12pm
The casting # is u3027,  from what I can tell from looking at valu built parts book that casting # is for a WD.  This is an earily 45 (1954) sn 39029, maybe these had WD style cams.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 6:05pm
The WD's and the early WD45's had the bolt on camshaft gear (three bolts) and the later WD45's had the pressed on camshaft gear that has a keyway. They both come apart. The tooth count is the same on both gears and I could never see any differences in the standard camshafts. I'm pretty sure that they'll interchange though. If anyone knows any better please let us know...Dr. Allis or anyone?  Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 6:10pm
That serial number is way off.
Are you sure you have a 45.
Look on the right side {Pass Side}} of the engine and see if there is a steel plate bolted to the block that runs the whole lenght of the block just under the head.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 6:18pm
What is the engine block serial number?
Does your tractor have the straight shifter or the curved one?
How many lines come out of the bottom of the oil filter housing base?
These question will help figure out what engine you have in that tractor.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 7:46pm
you  probably have a newer 226 cam that requires a press on gear.
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 8:05pm
If your new cam did not come with the timing gear installed, you just need to get the proper press on gear for your new camshaft. Any WC/WD/WD45 cam will freely interchange between models including the timing gears that all have the number of teeth on any of these engines. The cams all have the same lobe profiles as well.
79fordblake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 10:13pm
This method doesn't always work. I have my Grandpa's '57 WD45 and at some point in it's life the WD45 block cracked and he put in a WD block. I think he put the WD45 internals in it, he always used a 3 bottom plow behind it and I still use it and it has no problem pulling it in hard rough ground.
Edited by 79fordblake - 23 May 2011 at 10:25pm
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2011 at 10:44pm
the press on gear cam fits fine in any 226.got a 170 cam in my 45 and had to get the press on gear to install it
472bigblock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 472bigblock Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2011 at 6:50am
Be careful there are different # of teeth on cam gear for oil pump press on type camshaft early and late!!!!!!!!!!!!!!!!!!!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2011 at 8:12am
79fordblake, I know that. Trying to figure out just what he has between rears and engines.
