WD45 CAM
AC puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC puller Quote  Post ReplyReply Direct Link To This Post Topic: WD45 CAM
    Posted: 29 Oct 2015 at 7:32am
CAN SOMEONE GIVE ME ADVISE ON WHERE TO GET A CAM NEW OR GROUND FOR PULLING.AND WHOS ARE BETTER?
worldchamp19 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote worldchamp19 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2015 at 3:00pm
Where do you live?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC puller Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2015 at 11:57pm
western pa
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2015 at 12:59pm
I can give you some specs if I know what the engine specs are. As far as a grinder, there's several pretty good ones, all will have slightly different master lobes to work with and slightly different opinions. Getting a cam that isn't to big and getting it timed correctly to the crankshaft will be more important than anything else
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2015 at 1:02pm
I've got a couple on the shelf for smaller engines and lower end rpm range, depending on what you'll need one may be a good match. I just send several at a time to the grinder to make it easy.
mike a View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike a Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2015 at 7:08pm
berry cam  in lester prairie,mn ground me a 175 profile cam a few years back,not sure if they still do
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2015 at 5:55am
Which CAM profile would a "Z" code motor follow? 170?
Charlie
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2015 at 11:13am
Yup a Z code is a 170 engine
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
mgburchard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mgburchard Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2015 at 3:17pm
The secret to the best pulling cam for a siameeze intake port is one that's ground that makes the engine 2 two cylinders opposing each other .
