WD won't start
Embellem View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Embellem Quote  Post ReplyReply Direct Link To This Post Topic: WD won't start
    Posted: 20 May 2011 at 1:16pm
MY WD died very abruptly plowing snow this past winter and I'm now getting around to fixing it. It didn't sputter or anything like that, just completely stopped, like turning off the ignition switch, only I didn't hit the ignition switch.
Knowing it probably needed some electrical things replaced back from when I bought the tractor a couple of years ago, a week ago I replaced the spark plugs, spark plug wires, magneto rotor, points, and condenser. It still doesn't start and isn't getting any spark.
I know I need to go through it again and make sure I've got the things I replaced set up correctly. But beyond rechecking all the things I listed above, is there anything else I should consider?
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2011 at 1:43pm
If you're not a well-tempered magneto tech, I'd suspect that the mag isn't quite set up right.
Since you've verified that there's no spark, my recommendation is to pull the mag and take it to a mag technician (every area has that ONE guy who's really good with mags), have it gone through, then reinstall it properly (it is timed), and give it a whirl.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2011 at 2:06pm
Before yanking the Mag out, if you have a toggle or push/pull switch you're using up near the driver area for a Mag kill, disconnect the switch and see if it starts. Sometimes those switches go bad from the elements and it'll be grounded all the time... HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2011 at 8:59pm
If you have a kill switch like Steve is talking about, disconnect the wire from the mag, then you know it's not shorted out somewhere in between the mag and the switch.
This page was generated in 0.107 seconds.
