WD WD45 SHIFT TOWERS.
1946WP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1946WP Quote  Post ReplyReply Direct Link To This Post Topic: WD WD45 SHIFT TOWERS.
    Posted: 21 Feb 2012 at 9:19pm
DOES ANYBODY KNOW IF THE WHOLE SHIFTER & TOWER CAN BE CHANGED BETWEEN A WD TRANSMISSION & WD45 TRANSMISSION OR VISE VERSA?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2012 at 9:23pm
No, they are different.   MACK
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2012 at 9:25pm
I have to agree with MACK.  Remember the WD had straight gears while the very late WD's and the WD-45 had a constant mesh transmission.  You shifted collars and not gears.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2012 at 11:16pm
Won't it work if you change the forks to match the transmission?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2012 at 6:58am
No
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1946WP Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2012 at 8:18am
THANKS GUYS , I DIDN'T THINK SO BUT A FRIEND CALLED ME ,SAID HE INHERITED A WD THAT THE SHIFT TOWER WAS OFF & HE TRIED TO PUT IT BACK ON BUT COULDN'T GET TO WORK. FIGURED OUT AFTERWARDS IT WAS AN EARLIER   WD BY SERIAL # & HE WAS TRYING TO PUT A BENT SHIFTER ON IT. TOLD I DIDN,T THINK IT WOULD WORK , BUT I'D ASK THE GUYS THAT KNOW.THANKS AGAIN.
Post Options Post Options   Thanks (1) Thanks(1)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2012 at 9:40am
Mack, you're going to have to have a talk with my WD45 then. I used a NOS WD shift tower with the innards from the WD45, and except for the springs being too long (so I used the shorter springs, It seems to work fine.
Edited by TedBuiskerN.IL. - 22 Feb 2012 at 9:43am
This page was generated in 0.135 seconds.
