WD/WD45 Head Gasket ?
Lunker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lunker Quote  Post ReplyReply Direct Link To This Post Topic: WD/WD45 Head Gasket ?
    Posted: 12 Aug 2014 at 6:51pm
I need a WD Head Gasket for a 4.5" bore block! The standard gasket does not work! Where can I find a solid copper gasket or one with larger bore coverage?
Tanks, Lunker
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2014 at 8:26pm
Simply google copper head gasket, they are not hard to make yourself if your handy....
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2014 at 9:03pm
A copper one won't hold if you're going to make much cylinder pressure unless you o-ring the head or block. I cut groves with a tool I made in my milling machine and install a wire to protrude from one of the surfaces and bite the gasket. A little silicone or anaerobic sealer around the pushrod and water holes and it's a simple solution.
Clark Copper Head Gaskets in Blane Mn makes the gaskets, about $75 for one if memory is right and I've probably got some on the shelf. You can get about any thickness you want.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lunker Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2014 at 11:13pm
Thanks Wi50
Lunker
