wd/wd45 hand clutch spec.
Bob wi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob wi Quote  Post ReplyReply Direct Link To This Post Topic: wd/wd45 hand clutch spec.
    Posted: 19 Feb 2012 at 12:33pm
putting a wd45 hand clutch in the wd, took it apart and look's good what is the correct clearance between the clutch disc/plate's so I get it simmed correct
stu(ON) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stu(ON) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2012 at 7:47pm
0.065"
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2012 at 10:24pm
Have a look at the plate the rollers ramp up on.You can turn it to get a new place to run on.The edge of the angle can get rounded. Sounds like yours may not have that much use/wear.
This page was generated in 0.089 seconds.
