wd/wd45 eccentric pin snap ring question
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Topic: wd/wd45 eccentric pin snap ring question
    Posted: 11 Jul 2010 at 8:23am
Took a set of eccentrics and put them in my electrolysis tank to clean them up.  After two days, they spun easily, but I was going to take them all the way apart to clean up the eccentric pin and then reassemble with some antiseize.   Question is, does anyone have a source for the eccentric pin snap rings that are on the back.   Two of the four that I took apart, the snap ring just crumbled from being so rusted and getting eaten away in the electro tank.  I would like to buy a bunch of them so that I have some on hand and will put new ones on all eight pins that I get apart.  Thanks for any help.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2010 at 8:28am
Chuck, You might try Fastenal.
Don
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2010 at 3:03pm
Sandy Lake has them  888-252-0656
bigfish_Oh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2010 at 9:17pm
Chuck, I forget, was you going to make Dale's this weekend?
1941 WC sat for 29 years,started & dynoed 27 h.p.
1957 WD45 Grandpa bought new,factory p.s.,added wfe
1951 WD, factory p.s.
1960 D14 HnMk IV BkHoe 4 sale
2014 HD Tri Glide
2009 GMC CC SLT Dually
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2010 at 9:45pm
Don/Chuck...I went the Fastenal route last year w/o any luck....Dale
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2010 at 10:36pm
I think if you can find a spring of the same approximate dia, mount it on a bolt and run a die grinder down the length of it you can have a lot of them. I've been thinking of doing this, but haven't had the need yet.
ALLIS EXPRESS!
This year:
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2010 at 8:37am
Hey now Eldon,
That sounds like a plausible idea. I do a lot of innovating myself but never thought of that one. Thanks for sharing!!
BILLP-SE-MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BILLP-SE-MI Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2010 at 9:13pm
Hey a few years back I needed some of those lock rings. there was a place in Toledo Oh. Spring time Manufacturing. Here's what they helped me out with. I saw the guy put this spring on a cutting press and popped them off one at a time..
Chuck , How many do ya need. The one with tape is orignal
This page was generated in 0.085 seconds.
