WD tire rims |
Huolti ![]() Bronze Level ![]() ![]() Joined: 03 Sep 2017 Location: Alberta Canada Points: 38 |
![]() ![]() ![]() ![]() ![]() Posted: 13 May 2020 at 10:46am |
Re storing a WD and trying to remove rear wheels to paint rims. Can’t seem to find the right socket to loosen eccentrics. Is this a special socket.The bolts don’t seem to be chewed up from previous removal. The bolts have a stamp on them like small pin holes. Thanks
john(MI) ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: SE MI Points: 9262 |
If you want to paint the rims you will need to take the wheel apart. the easiest way is to lay the tire down. Remove the 8 bolts holding the eccentrics to the rim and then give the center a couple good wacks with a sledge onto a chunk of wood. The eccentrics require a six sided socket. I can't recall the size but it is a standard SAE size.
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 5043 |
3/4" fits tight. I always use a 6 point 3/4" drive impact socket. Sometimes you have to tap it to get it on.
Sugarmaker ![]() Orange Level ![]() ![]() Joined: 12 Jul 2013 Location: Albion PA Points: 8535 |
Huolti,
Welcome and we need some pictures! Those excentrics can be from bad to worse! I have taken apart and loosened maybe 50 of them. I would do as others have said. If you havent already. Remove the wheel/ tire assembly from the tractor (8 lug bolts) Lay the tire down with the center facing up. Take out the 8 bolts that hold the eccentric castings to the center rim. Gentle tap out the center rim with one of these. (my suggestion would be the 16 lb on the right):) ![]() Then you will have all the parts loose and you can clamp the eccentrics down and start to work on getting them loose again. Regards, Chris |
Thanks guys will try that. Dreading taking the rim off as there is already some broken off studs.
Broken off studs. Well yes that can be a real issue too. I fought with one for half a day. I won. Heat, drill, easy out, (they never work) more heat, vice grips, more drilling, ......
re- tap. Good as new! ![]() Regards, Chris
