WD Shifter Question
HayMaker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HayMaker Quote  Post ReplyReply Direct Link To This Post Topic: WD Shifter Question
    Posted: 22 May 2010 at 3:04pm
I just bought a WD today with a 2 row cultivator, but something is screwed up in the shifter.  When I went to take it out of reverse, the shifter popped loose and now it just flops around.  When it came loose it went into 3rd gear.  Is there a roll pin in there that I broke or is it something else?  Thanks
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2010 at 4:05pm
Hi,  It is important to know if this is a WD or wd-45 - the shifter is curved.
Take a good look at what you have then get back to us.
It could be as simple as a problem with the shifter.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote HayMaker Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2010 at 9:12pm
It's a WD, it runs pretty good, has a crack in the exhaust manifold though and the body is pretty rough, but it doesn't smoke and with some fresh gas, we had it running pretty good, but the shifter popped out backing it off of the trailer, and not it seems like its not engaging the shift rods.
