WD sediment bulb issues |
SteveRogers ![]() Bronze Level ![]() ![]() Joined: 21 Jun 2023 Location: Geneseo, IL Points: 23 |
![]() ![]() ![]() ![]() ![]() Posted: 04 Dec 2024 at 9:07pm |
Having problems with the fuel shut off valve on my WD. It leaks and I can't get it to stop leaking. Appreciate and help I can get.
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3931 |
take the bowl off gasket and screen and take a screwdriver or good sharp narrow scraper and scrape the gasket area until all the oxidized aluminum is gone and it is smooth and it will seal
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22021 |
With a 7/16" wrench, tighten the nut on the shut-off valve until there is drag on the shut off handle when you turn it in and out.
Alberta Phil ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3930 |
Unscrew the packing nut on the shutoff shaft and make a small string of teflon plumbers tape by twisting it. Wrap it around the shaft and poke it into the nut. Then slide it back into place and tighten the packing nut 'til it stops leaking.
Ray54 ![]() Orange Level Access ![]() Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4753 |
Be careful you can bend the base where the bowl and gasket sits if you over tighten the glass bowl. So a new gasket is a good place to start if the bowl leaks rather than the stem of the shut off. I have used o rings and other rubber washers in a pinch.
Ed (Ont) ![]() Orange Level ![]() ![]() Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1503 |
As others have mentioned it could be leaking at the shaft not bowl so check that. Mine is doing that so now I just leave it on all the time and no leaks. I will try what Doc suggested - just noticed that comment and it makes sense!! I will report back.
