wd power steering question
dsgraf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dsgraf Quote  Post ReplyReply Direct Link To This Post Topic: wd power steering question
    Posted: 25 Dec 2010 at 12:52am
looking at a char lyn gear for power steering on my 1952 wd and wonder why you can't use the factory hydraulics to power it? is there a reason why this won't work and has anybody tried or done this. my only use for tractor is plowing driveway in winter and backing trailers in. please coment.
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2010 at 12:58am
The high pressure and low flow system of the factory hydraulic system is not compatible with the Char-lyn system.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2010 at 7:34am
Even if you could plumb in a priority valve and a relief valve to get the pressure down to what you need,you probably wouldn't have enough volume and you wouldn't have steering when you push the clutch in.
