WD Parts? Scrapping...
rasman57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rasman57 Quote  Post ReplyReply Direct Link To This Post Topic: WD Parts? Scrapping...
    Posted: 10 Mar 2024 at 7:52am
My next door neighbor recently bought an old farmstead and is cleaning the place up.  He is going to part/scrap this old WD, which he  (and me) know nothing about.    Any parts in the photos are available very reasonable, and nothing has been removed since he uncovered it.  Hinckley, IL 60520   Message me if interested.
Edited by rasman57 - 10 Mar 2024 at 7:56am
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2024 at 8:05am
Actually looks like a WD45, but it's hard to tell since the shift lever is missing and it's hard to see the side of the engine, but it does have a distibutor.
There are some parts that people look for (distributor, drawbar, PTO, etc.). The sheet metal actually looks pretty good in the pictures.
That seat is not right for the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rasman57 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2024 at 8:17am
Good info...thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2024 at 8:49am
Serial number is on the rear housing under the left brake cover. You might need to use a wire brush to see it. If it's after 146,606, it's a WD45.
groundhog55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote groundhog55 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2024 at 1:23pm
Looks like a WD engine
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2024 at 1:37pm
Hard to tell if it's a 3'' or 4" head. I couldn't tell if it had the side cover or not.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2024 at 8:29pm
I can see the side plate and the short head. Pin hitch drawbar. Short fender brackets. WD all the way.
PawPaw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PawPaw Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2024 at 4:51am
Are my eyes that bad or is the top of the final drive rotted away
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2024 at 5:56am
Mag conversion, short head, low fenders, early tool box, early hydraulic rod, cast steering support, hole in the radiator grille. 48 or 49 WD. One or two of these come up for sale every week. They are going away fast.
http://lonsallischalmers.com
This page was generated in 0.488 seconds.
