WD or WD45 parts
Red View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Quote  Post ReplyReply Direct Link To This Post Topic: WD or WD45 parts
    Posted: 01 Nov 2010 at 7:49pm
Recently aquired a disassembled engine.   The block has  W7570 on the back end also has U 3019-5 on the side.   Crankshaft has  U ?986  the connecting rods  have  U 3988 on them.   Do all these parts work in the same engine and would it be from a WD or a 45?   Thanks for any help.
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2010 at 7:57pm
I would say from the serial and casting # on block that it's an early WC, 1934-1935. The WC/WD block has a plate bolted on the right side behind the mag/oil filter and the WD45 has a smooth one piece block.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2010 at 8:10pm
The unstyled engines had the engine serial number stamped on a pad in the center rear of the block just above the clutch housing. When starters were available with the styled tractors the serial number was moved to a pad on the left side of the block.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2010 at 8:41pm
I checked a couple of my WC's and I'd say you have a 1935 WC block. The suffix on the casting of my 1934 is 3 and on my 1936 it's 8 so your's falls in between there somewhere. I know from my engine serial #'s that they are the correct engines for the tractors. I have suffix #'s into the 30's on the newer ones so the suffix must not follow the year exactly as  they do on the B/C/CA blocks.
Red View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2010 at 7:14am
Never even considered it being a WC.   I was thinking early WD.  Still wonder if I have the right crank and rods.    Was there much difference between the WC and WD engines?   Got a brand new set of pistons and sleeves  with this.   Hope they bought the right ones for it.    Thanks for the help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2010 at 1:57pm
WC and WD were pretty much the same engine.
Red View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2010 at 7:41am
Thanks for the information.  Now I need decide what to do with these parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2010 at 7:50am
The very early WC's, of which yours may be one, had a smaller crankpin journal than the later ones.  By the casting numbers, I'd say you have a small journal crankshaft. The rods will be different and have a smaller big end.
Red View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2010 at 8:00am
Where would a person look to find engine specs for the WC and WDs?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2010 at 5:31pm
This page was generated in 0.107 seconds.
