WD loader questions....
cbuttre835 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cbuttre835 Quote  Post ReplyReply Direct Link To This Post Topic: WD loader questions....
    Posted: 27 Nov 2010 at 5:14pm
OK, on the local Craigslist there is a guy with a WD and loader for sale... says the "loader will need new cylinders per the owner" (owner is elderly, doesn't have internet access, so he's listing it for him).
A couple questions - will this loader and frame fit a D-15?  If not, I assume it will fit a WD-45?
What do new / rebuilt cylinders run, cost wise?  I haven't seen them so don't know why the owner would say that they need replacing... wonder what the "point of no return" is for rebuilding them or replacing them?
C w/ 3rd gear out
D15 II factory 3 point
WD (no motor!)(parts for sale!)
WD 45 wide front
John (MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (MO) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2010 at 5:44pm
You should have no problem making the loader fit.  May need a couple new hole in the mounting plates.  I've seen the same loader go from a D-14 to a WD to a D-19.  Cylinders can be rebuilt, depending on what's wrong with them.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2010 at 5:56pm
as John says, the cylinders are rebuild able, real cheap. I have a pair that were pretty badly pitted and scratched. I repacked the seal with packing rope and it works real fine, weeps a little more than they should, but works fine. If the loader is a W-9, It will fit a WD/WD-45, but I don't know how much it would take to mount on a D series, like John says, maybe only a hole or two
I am still confident of this;
Wait for the Lord;
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2010 at 9:33pm
You will have to measure the tractor frame width to be sure it will fit.
I have a loader on a D-14 and want to put it on a D-15, but I know the engine frame is wider. Bob
