wd lift arms on d17rock shaft
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: wd lift arms on d17rock shaft
    Posted: 06 Feb 2024 at 9:03pm
can i put the lift arms fron a wd on the rock shaft on a series 1 d17 and useing the wd lift cylinders with the cylinder inside
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2024 at 6:00am
Don't think you'll have enough spline length to do that. Maybe, but I don't think so.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2024 at 6:31am
#1 Why would you want to do this?
 #2 the WD/WD45 lift cylinders attached to a separate arm than the actual lift arms.
 #3 if you are looking for extra lift capacity, there was a kit to add external lift cylinders.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2024 at 11:35am
paul b #3 yes i seen one of those kits thinking i could make some brackets to fit on the axle tube mounting with longer studs  , dont remeber what the mounting looked like onthe kit that goes on the tractor side , if it bolted to the axle or some where easle, will try to get out to the wd and measure the splines and weasure the d17 splines .         are they tapered ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2024 at 11:56am
never mind not nearly long enought lenght on the d17 splines so  i will make the parts like the kit i know some one had a picture of it not long ago but a part number would be good if some one knows what it is so i can look it up,  and may be locate one or fab the parts
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2024 at 6:56pm
The arms that bolt to the lift arms for the extra capacity D17 package are very much like the bolt on pieces that the forward control rods attach to for front mount cultivators.  So that might be a place to start look for parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2024 at 8:12pm
thanks i am going to get in the agco book and take a look right now
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2024 at 8:54pm
no luck finding pictures or part number in parts book but probley didnt word it right on web searches  will lok some more tommorrow
