Wd Hydraulics
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Topic: Wd Hydraulics
    Posted: 25 Sep 2010 at 8:28am
First off, I picked up a V-belt pulley assembly that replaces the wide belt pulley. I guess they used them on the WC from what I understand. I don't think it was ever used from the looks of the drive gear. Looks like it takes a 5/8 belt.
I considering using that pulley to drive a pump for the 3 point and remove the factory hydraulics all together. Change the cylinders to low pressure/high volume and block off the pump hole.
The reason being is my OE pump is about wore out anyway..
The question is....What should pump volume be for just those 2 cylinders?
Im thinking about 5 gpm. Don't know if that is enough or not.
What do you think?
