wd hydraulic pump
tracy 1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tracy 1 Quote  Post ReplyReply Direct Link To This Post Topic: wd hydraulic pump
    Posted: 18 Jan 2016 at 9:31pm
I have a wd  with what I thought was a bad hydraulic pump ,I had a parts tractor on the farm that I never ran and switched out pumps and still nothing , the cam that runs the pump is functioning ok and I have the proper fluid in it, could it be a second bad pump ? is there  A way to prime it? or do I need to ? I cracked the fittings while the tractor was running and nothing, The fluid went from clear to looking like it was cloudy with air bubbles , any ideas
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2016 at 9:37pm
Just need to take them apart and replace or free up parts along with some new springs and orings.    MACK
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2016 at 8:09am
I tell people that it's better to rebuild your pump than you install another used one. Usually the used one has problems too.
Go through your owners manual and make sure all your linkage is adjusted correctly. After that, get a service manual and start checking things. Most likely you have some broken check valve springs.
While you're at it. buy a 5000psi hydraulic pressure gauge and put an end on it to plug into your remote outlet so you can check pressure. You can't tell what's happening if you can't check your pressure.
I have mine off for the 4th time right now. I think I have it narrowed down to a bad relief valve. Bought a good used one to install and try.
Edited by Allis dave - 19 Jan 2016 at 2:42pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2016 at 9:51am
Welcome to the BEST forum on the internet!!
Yes, #1 is to check your linkage to make sure it is set WHERE it is supposed to be.
Do you have a manual??  If NOT, that is the FIRST thing to do.
Theere are a LOT of threads on here about this.  All you need to do is search.  If after you get the manuals and you need help, all you have to do is ask.  You can also PM me and I will try to help you out.
These are really easy machines to work on.  Don't be afraid to ask questions or try what is suggested.  I once was scared to do anything on these, but with all the help on here it is pretty easy after all.  Don't be afraid to work on these and don't be afraid to ask.  There are NO dumb questions!
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2016 at 1:40pm
My pumps lift fairly decent, noisy but do lift , On all my wd's and also my 45's wont hold the load steady.--it either goes up or down on its own.---as near as I can tell the valves are screwed in OR out as per specs but none of them will hold at needed height.---I fought the plow and bushogger last fall, just to get things done before bad weather and this spring I gotta fix something,--just don't know where to start or what to do! thanks; ac fleet
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2016 at 2:27pm
Always start by going through the owners manual and adjusting linkage. The springs behind the quadrant need to be good and the friction blocks need to be good. The spring behind the quadrant put pressure on the friction block and keep the lever from creeping up. A broken spring will let the lever and plow creep out of the ground causing you to hold the lever all the time. If you're curious, ask me how I know...
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2016 at 7:52pm
Holding the lever does nothing! Plow still goes down! thanks; ac fleet
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2016 at 7:17am
Best thing is to get both an owners and service manual. Both of these together explain all the workings of the pumps. Can be bought on e-bay or from site vendors for about $20 each.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2016 at 11:49am
I have several manuals, but not much in the ones I have to be of any help.  Thanks ; ac fleet
DON G View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DON G Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2016 at 1:57pm
I had one that was not pumping. Spring on top was broke. I think you just take out a bolt or screw to get to it.
