WD Handclutch
Wot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wot Quote  Post ReplyReply Direct Link To This Post Topic: WD Handclutch
    Posted: 30 Dec 2021 at 2:10pm
I’m having some trouble with the handclutch of my WD. It kicks out if the tractor is not under load. I have removed shims, but it stil kicks out when not under load. When it is under light load, driving uphill, it stays engaged.
It looks like the plate where the rollers need to roll over is worn out. But I’m not shure if that could be the problem? Maybe i can adjust something else?
Thanks!
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2021 at 9:07pm
Engauge clutch, remove front snapring (wire ring) , Engauge clutch, rotate over center plate to new location. Engauge clutch, replace snapring and your ready to go. Over time it may work itself back. While top is off, make sure no pins have come out of linkage.                        MACK
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2021 at 10:36pm
Probably need to put the shims back in too..
Wot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wot Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2021 at 5:49am
Great help, thanks! Will try and let you know.
Wot View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Wot Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2022 at 8:52am
Problem solved! Thanks!
This page was generated in 0.152 seconds.
