WD hand clutch pivot |
Matt Tallant
Topic: WD hand clutch pivotPosted: 06 Dec 2017 at 11:24am |
Can it be changed with tranny still in frame?
Gary(VA)
Joined: 13 Sep 2009 Location: Troutville, VA Points: 351 |
Posted: 06 Dec 2017 at 11:47am |
It would be easier to just remove the side rail. Pull off top of trans. I couldn't get mine to move out so I cut it of and drove it through. Freeze the new pin a bit before installing will help.
Gary(VA)
Posted: 06 Dec 2017 at 11:50am |
Should have also said that except for early tractors there are bushings in the handle to change. I had the right side drill to just drill the old ones out. I would think you might be able to drill out one that never had them. If you need the drill but if you don't have that size just let me know and you can borrow it.
Actually just put the weights on I got from you this past weekend. |
Matt Tallant
Posted: 06 Dec 2017 at 4:00pm |
Send me a text Gary 540-953-1556
Lon(MN)
Joined: 11 Sep 2009 Location: Merrill Wi Points: 2048 |
Posted: 07 Dec 2017 at 6:51am |
I used a six foot pry bar, used the frame rail as a pivot and pushed it in.
