WD hand clutch handle free travel
J.Bronk(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote J.Bronk(WI) Quote  Post ReplyReply Direct Link To This Post Topic: WD hand clutch handle free travel
    Posted: 30 Mar 2011 at 11:15pm
Hi, I have a WD and the hand clutch handle has a lot more free travel than  I'm used to on my 45. It makes a nice snap when it releases and doesn't seem to slip, it's just that the handle is out comfortable reach to re-engage and adjusting the linkage so I can reach it puts the lever at my hip when engaged. Any ideas? Thank you, Jim
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2011 at 6:32am
you may want to remove the inspection plate to be sure all of your plates are there. on my wd45 it's under the main battary. i shound warn you to drain the oil first. the plug is on the bottem of the pto housing. also check all linkage shafts for wear/play as something may need replacemet.
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2011 at 6:58am
Maybe your missing this?? I can ship this to you if needed.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2011 at 11:23am
The brass yoke or steel collar can wear or the setscrew holding the shift fork to the shaft can come loose.   Take the battery box off, take the cover under the battery box off, move the lever-should be able to see whats worn/loose.
This page was generated in 0.071 seconds.
