wd governor lopeing- help?
clint View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote clint Quote  Post ReplyReply Direct Link To This Post Topic: wd governor lopeing- help?
    Posted: 07 Jun 2010 at 9:45am
i had to put new weights in the gov on my wd- the old ones flew apart last summer
back together, times- sounds ok at idle
at fuller thot it sometimes kicks int he gov in and out- how do i stop this?
Our farms stuff: agco gt55, AA 8775, 8765, 6080, 185, 180, 175, 170, d15, d14, d14, wd, wd, wd, g, F3, L3, R62
Post Options Post Options   Thanks (0) Thanks(0)   Quote clint Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2010 at 2:46pm
bump- need the help!
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2010 at 3:05pm
Clint, There is a small spring part no. 70203208 on the rod from the cross shaft to the carb that is supposed to control surging. If it is broken or unhooked it could be causing your problem.
If you have a parts book look at the governor breakdown to see where it is located.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2010 at 5:47pm
It probably just needs the rod going to the carb to be adjusted correctly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2010 at 6:01pm
Most of these old tractors have lots of slop in the gov. linkage. The anti surge spring John is talking about is more critical with older tractors because of this. If you can manually grab the throttle shaft of the carb and hold it steady to stop the surging, you will need to either tighten up the slop or add the spring or both.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2010 at 6:03pm
We have the spring listed on our website.  We sell quite a few of them.  Can really make a difference to stabalize the gov.
Owner of OKtractor.com PM for an instant response on parts. Open M-F 9-6 Central.
We have new and used parts. 877-378-6543
