wd front steering housing
LaJaMe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LaJaMe Quote  Post ReplyReply Direct Link To This Post Topic: wd front steering housing
    Posted: 28 Jan 2024 at 11:06pm
Going thru my 50 wd and found the steering housing on the front to be dry.  I have manuals but cannot find what the capacity is.  Any help would be appreciated.  Going to NAPA to see what they have in NGLI 00 or 000  I do have 85/140  Thanks
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2024 at 6:06am
If it's dry, it must leak.
I, personally, use John Deere Cornhead grease for any gearbox that leaks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LaJaMe Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2024 at 1:12pm
Thanks WF Owner  Probably going that direction, but can't find the housing capacity
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2024 at 1:27pm
Just fill it until you have the gear covered when looking through the inspection plate, like it says in the operators manual.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LaJaMe Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2024 at 1:46pm
Ok. Thanks. Didn't see that in the manual
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2024 at 4:09pm
I think it's hold about a gallon or so. I fill mine up until it starts to coem out the front  hand crank hole. Of course then it leaks out there for awhile.
1963D17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1963D17 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2024 at 10:57pm
Corn head grease is what I use
This page was generated in 1.650 seconds.
