WD crankshaft pulley |
SteveRogers
Joined: 21 Jun 2023 Location: Geneseo, IL Points: 23 |
Topic: WD crankshaft pulleyPosted: 18 Jan 2025 at 11:07am |
I think it's my crankshaft pulley that is broken. Fan and power steering belts aren't turning when the tractor is running. Looks like a cast iron piece is broke out of part next to where the crankshaft comes out. How big of a job is it to get to this piece? Any tips or suggestions on how to get to and fix this part would be appreciated.
Nathan (SD)
Joined: 11 Sep 2009 Location: Day County SD Points: 1304 |
Posted: 18 Jan 2025 at 7:23pm |
You really need to disassemble it to see actually what you need to do. If it is a Char-Lynn pulley causing the trouble you might need to get creative on a solution or buy a new double pulley all together.
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5911 |
Posted: 18 Jan 2025 at 9:11pm |
To get to the Pulley: drain the Rad remove the Hood remove the Rad Cover Shell remove the Rad, don't forget the 2 @ 3/4" socket bolts that are accessed from under the Rad. Now I think the Crankshaft Pulley should be accessible. G |
Posted: 19 Jan 2025 at 7:21am |
I would be very concerned about what condition the crankshaft snout is in after this kind of failure.
SteveRogers
Posted: 23 Jan 2025 at 2:59pm |
The crankshaft pulley does not appear to be broken in any way. But there is another part that goes over the top of the pulley and has 4 set screws that attach it to the pulley. What is this part for and how I know what should be the tolerances should be or how should it be adjusted to the crankshaft pulley?
Nathan (SD)
Posted: 01 Feb 2025 at 9:34pm |
That is the Char-Lynn pulley. It is an add on to spin the power steering pump.
A total disassemble is in order to see what parts are salvageable. If that pulley came loose, there is a pretty good chance it is wore too much to hold onto the crankshaft pulley.
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6126 |
Posted: 05 Feb 2025 at 8:01am |
Steve- I sent you a PM- I'll be back in the QCA this weekend, I can come over for a look and help you find a solution.
