Wd clutch pedal return
Brampton 02 gt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Topic: Wd clutch pedal return
    Posted: 21 Apr 2017 at 8:28pm
I put a new clutch/brake pedal shaft. The pedals were also machined. The clutch pedal doesn't snap back nicely like it should. Should I have greased it better. I used the zirk but it might not cover the whole shaft. I wonder if the tolerance is too tight or could the spring be week on the throw bearing. Is the spring easy to change?
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2017 at 10:34am
Everything you mentioned could cause the issue. I would remove clean and grease everything and if it still sticks then try a new spring. You should be able to replace the spring through the bottom access window.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2017 at 5:22pm
Found the problem. Too many shims on the brake side of shaft was binding ped into housing.
Thanks
