WD clutch alignment tool |
WD45 Aaron
Topic: WD clutch alignment toolPosted: 25 Nov 2019 at 8:56am |
I made a drawing for a clutch alignment tool for WD clutches et al. Most of the dimensions are somewhat arbitrary. The only ones that really matter are the pilot and spline diameters and maybe the pilot length. I measured two clutch plates and the I.D. of the spline is about 1.022". The pilot bearing I.D. is 0.984" (25mm). I show the tool being made from 1-1/4" round bar because that's a common size. I actually made mine from 1-1/8" O.D. 5/8" I.D. steel tubing because I had it available and it was less material to remove in the lathe. I also got a little fancy and welded a 5/8" nut to the back and made a T handle, but it really wasn't necessary. A guy probably could get away with just using 1" round stock for the spline diameter, but the fit wouldn't be quite as good.
Machinery rescue for all things rusty or broken. Current residents include 2-1/2 WD45s, Oliver Row 77 gas, Farmall super C, two Cat D2's, Clark C500-80 forklift, and a sick Kubota.
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8661 |
Posted: 25 Nov 2019 at 10:04am |
Aaron,
Good design and build on the clutch alignment tool. That will make the installation go much better!
Regards, Chris |
Stan IL&TN
Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
Posted: 25 Nov 2019 at 11:45am |
There I went and thought I had did something great when I used a deep well socket over the use of a broom handle. Just teasing you Aaron. It looks great!👍👍
1957 WD45 dad's first AC
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25256 |
Posted: 25 Nov 2019 at 1:05pm |
dang, all I did WAS use a broom handle when I did "D-14 Troy" back in 2000. Still going strong today... Local garage tossed out ALL of their alignment tools as clutch 'packages' now come with tool....
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4278 |
Posted: 26 Nov 2019 at 8:45am |
I cut the splined end off a junk input shaft, works good!
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2584 |
Posted: 26 Nov 2019 at 4:53pm |
I use a junk input shaft too. I think DJS Parts sells a plastic alignment tool for $10 or so. If I had a lathe, I'd probably turn yours just for the fun of it though. AaronSEIA
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8982 |
Posted: 26 Nov 2019 at 5:29pm |
Did similar for T limiter in 8070. Pilots in back of crank(no brg). Lets you get it together before the "burnish" to true it.
