wd carb help please |
graveyard
Topic: wd carb help pleasePosted: 12 Jun 2018 at 9:05pm |
Need a little help. Not a great carb man. Bought a wd with a gleaner z in it. wouldn't idle so I changed some things and got it to idle. In the process of taking apart several times it will now idle but when I give it gas it kicks the governor in and out in and out repeatedly. If I fool with the load adjustment it will smooth out but as soon as move throttle does the same thing again. Throttle rod may be an 1/8 to a 1/4 inch short. Could it be this or in the load adjustment needle?
Posted: 13 Jun 2018 at 7:13am |
Governor link rod too short will make the governor more jumpy, so it could be your problem, but not guaranteed to be your problem.
graveyard
Posted: 13 Jun 2018 at 8:25am |
thanks dr allis that's what I was thinking they had tried to modify it for speed pulling and made it a little shorter.
