WD Brake Question, Diff. Seal #'s |
Mike56073 ![]() Silver Level ![]() Joined: 14 Nov 2010 Location: New Ulm Points: 154 |
![]() ![]() ![]() ![]() ![]() Posted: 07 Mar 2012 at 8:55pm |
Hey guys,
On a WD, I've got the brakes out, and the linings are about 1/4" thick. How thick are new linings? I also have one brake drum with 1/8th inch deep grooves in it, does it need replacement ? Second question: Does anybody have seal numbers for the differential ? I'm talking about the 2 seals that go into the end caps on either side of the diff.
I would replace the linings while they are out. The drum should be ok if the major OD is ok. MACK
RickinNH ![]() Silver Level ![]() Joined: 09 Dec 2011 Points: 154 |
The new pads i have came from Valubilt and are less than a 1/4 thick new. .223 thick. If the pads are not scored like the drum give some thought to not replacing them. The new rivet installation takes some time to develop a method of doing. Search some older posts before you make up your mind.
