WD 45 wiring |
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 12009 |
![]() ![]() ![]() ![]() ![]() Posted: 15 Oct 2010 at 6:58am |
We can fix ya up with a complete 12V conversion kit if interested. I give you everything in the kit to do a pro wiring job except ambition. That you have to supply. LOL! Drop us a line, be happy to help you out.....
Matt MN ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: Silver lake MN Points: 1491 |
Rod in MN ![]() Silver Level ![]() Joined: 16 Sep 2009 Location: Rice MN Points: 290 |
Hi Guy's yes the coil and points were all changed over to 12volts.just need wiring diagrame
Thank You
Rod in MN
KC-WD45 ![]() Silver Level ![]() ![]() Joined: 11 Oct 2010 Location: Kansas City Points: 114 |
I use a resistor to the coil. Starter shure spins with 12v.
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7516 |
You will need a 12 volt coil and condensor. Lights should be ok if you already put 12V bulbs in. Should not have to make any changes to the wiring after this.
HI Guy's I have a WD45 that i'm switching over to 12volts Genny and a 12 volt reg.It has a pull rod for the starter installed a new key switch . Bur want to use the old light switch the bulbs are changed over to 12 volt . would it be easer ti get a cutout and switch over to 12volt . It has a distriutor on it Do's sone one have a wiring diagram for this .
Thank You Very Much
Rod in MN
