wd 45 manifold
wood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wood Quote  Post ReplyReply Direct Link To This Post Topic: wd 45 manifold
    Posted: 26 Mar 2011 at 8:54pm
I need a manifold. Should I by a new remanufactured one or look for a use one ?
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 9:06pm
Our WD has the WD45 manifold and carb on it, and it runs very lean in the cold weather.  Dad thinks with the original manifold and carb, that problem would be mostly solved.  The after market manifolds are the same for either engine, but the originals were definitely different-including the carb.
Greg Kroeker
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 9:10pm
I bought a new one about 20 years ago. I had to grind off the back edge to clear the air cleaner but it has worked great ever since. Back then I didn't have access to all these guys that part things out though. If you buy a used one, figure on having it milled flat before you mount it up.
GT in Indiana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GT in Indiana Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 10:16pm
Put a new one on my in-law's 53 wd.  Works great.  i thought about  a used one but 60 yrs of heating and cooling, hidden cracks, warping, etc... I didn't want to take the chance of getting a bad one.
My two cents...
1955 WD45 we like to call Ruby
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2011 at 10:21pm
Wood,
I have a verry nice WD45 manifold, used but not to old from a core engine I took apart.  I blasted it and painted it with some nice exhaust paint after I tapped the holes and set it up in a mill and surfaced it.  Can't tell it from a new one except a little carbon in the exhaust runners.
I'd sell it for $75 shipped to you if you're interested.
