WD 45 Hyd pump leak
bryan123 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bryan123 Quote  Post ReplyReply Direct Link To This Post Topic: WD 45 Hyd pump leak
    Posted: 18 Aug 2023 at 11:11am
My pump leaks from the plate of the D adjusting screw and also from the screw threads.
The four 1/4 bolts look like they would hit the bell housing before coming out to remove the plate and replace the gasket. Does anyone know if this plate and screw can be removed without taking out the pump
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2023 at 9:16pm
Take pump out and rebuild it. New check ball springs, o rings, gaskets, and a good cleaning. Most likely been 60 years of good service.                MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote bryan123 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2023 at 11:13am
Thank you Mack.
I have heard that taking the pump out going down is easier. Do you know anything about that ? Can the whole assembly be kept together including the control assembly ?
If I wanted to send it out for rebuilding as you suggest, who would be the best. I live in Wisconsin.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2023 at 1:59pm
out the bottom in the top
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2023 at 2:32pm
Sandy Lake can rebuild it. You can rebuild it yourself if you have a service manual and are mechanically inclined.
Before you remove the pump, do yourself a big favor. Put a gauge on the remote outlet and see what pressure you're getting. You want 3000-3500 PSI.
This will give you a look into what needs done on the pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bryan123 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2023 at 2:38pm
Thank you for the response.
Perhaps you or another WD affectionado could advise on something else.
The shaft that the wet clutch operatingh arm is fastened to has a leaking seal. However the operating lever arm is permanently fastened to the shaft for some reason instead of being clamped. I want to cut or grind this lever off so I can just slide the seal out and replace it then either clamp or weld the lever back on. This would be alot better than pulling the whole unit apart to get the shaft out. Has anyone a  comment on this ?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2023 at 9:14pm
Remove top cover under battery, place jack under belly, remove right frame, remove setscrew on inside fork, and remove shaft.                  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote bryan123 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2023 at 10:22am
Thank you Mack
This page was generated in 0.091 seconds.
