wd 45 diesel nose cowl |
j.w.freck ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: karnack texas Points: 1153 |
![]() ![]() ![]() ![]() ![]() Posted: 22 Nov 2010 at 9:05pm |
can any of you gurus out there tell me if a wd 45 nose cowl off of a gas 45 will fit on the 45 diesel.thx
Eldon (WA) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
I don't think so....my brother had to get the gas tank, hood and cowl off a gas when they converted one a while back.
Edited by Eldon (WA) - 22 Nov 2010 at 9:20pm |
ALLIS EXPRESS!
This year: |
Ray ![]() Orange Level ![]() Joined: 21 Sep 2009 Points: 1979 |
Not sure. I do have one off a WD45D $100.00 785-353-2392
Pa.Pete ![]() Orange Level ![]() ![]() Joined: 01 Oct 2010 Points: 239 |
I believe the only difference is the Hood.
skipwelte ![]() Orange Level ![]() Joined: 29 Oct 2009 Location: Anthon, Iowa Points: 723 |
Im thinking the difference is the size of the holes in the two wing pieces that bolt to the frame. The diesel cowl has large bolts holes. Thats the only difference I found between the two cowls. HTH |
ALinIL ![]() Orange Level ![]() ![]() Joined: 20 Sep 2009 Location: Frankfort, IL Points: 316 |
J W - The 45 and diesel Rad. Shells are the same. The shell for a WD, WD45 with shutters was different as it had hole for the shutter crank.
thx al i thought that was the only difference,but was not sure,thx again ...
