WD 45 Diesel block cracks?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: WD 45 Diesel block cracks?
    Posted: 01 May 2011 at 6:29pm
I have a friend building a 45 diesel. The block is cracked between cylinders  at the top where counterbores are. Is this a problem on the Buda block? No cracks at bottom visable. Any Help appreciated. Thanks Tracy Martin
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 6:31pm
I don't know many diesel engines, that get used, that don't have those cracks, many on here had said you will be fine.
Still in use:
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 8:52pm
you show me 10 230 blocks qand i will show you 8-9 of them that are cracked inter cylinder,usually between 4-5-6 jugs.as long AS THEY ARE NOT CHUNKED OUT  BETWEEN THE OIL  PASSAGES AND THE WATER JACKET they are good to go.the head gasket will seal the intercylinder cracks
