WD 45 Diesel block cracks? |
Tracy Martin TN ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10755 |
![]() ![]() ![]() ![]() ![]() Posted: 01 May 2011 at 6:29pm |
I have a friend building a 45 diesel. The block is cracked between cylinders at the top where counterbores are. Is this a problem on the Buda block? No cracks at bottom visable. Any Help appreciated. Thanks Tracy Martin
Orange Blood ![]() Orange Level ![]() ![]() Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
I don't know many diesel engines, that get used, that don't have those cracks, many on here had said you will be fine.
Still in use:
j.w.freck ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: karnack texas Points: 1153 |
you show me 10 230 blocks qand i will show you 8-9 of them that are cracked inter cylinder,usually between 4-5-6 jugs.as long AS THEY ARE NOT CHUNKED OUT BETWEEN THE OIL PASSAGES AND THE WATER JACKET they are good to go.the head gasket will seal the intercylinder cracks
