WC steering adjustment???
split51 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote split51 Quote  Post ReplyReply Direct Link To This Post Topic: WC steering adjustment???
    Posted: 17 Aug 2010 at 1:14pm
  How do you adjust for slack between the worm gear and steering gear on a 35 WC narrow front?
Edited by split51 - 17 Aug 2010 at 5:07pm
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2010 at 2:18pm
Might be the keyway in the bottom where the spindles go on the verticle shaft worn. Also check the looseness in the steering Ujoint.  Thats about it. HTH  good luck
Good View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Good Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2010 at 2:19pm
Usually the slop in that is from the pedistal housing the rack shaft goes down through there is no bushing there but you can machine to put one there.the only adjustment up there is to take shims out to tighten worm gear bearings.
B212,716,two 314H's,WC,WD,D19,190XT
