wc rebuild
kblank05 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kblank05 Quote  Post ReplyReply Direct Link To This Post Topic: wc rebuild
    Posted: 20 Oct 2010 at 6:39pm
ive been restoring my wc for about 3 years now. 2 years ago i rebuilt the engine all new everything, had the head work done and all..  no im trying to time it to get it to run, but i have no compression on number 1, i have comp. on 2,3,4 but not zip on 1...
what could be going on here? i know the rings arent lined up for sure and i checked for proper end gap when putting it together.....  any ideas. thanks in advance
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2010 at 6:40pm
valve sticking open or some crud on the seat?
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2010 at 6:42pm
Maybe pull the cover off to make sure a valve isn't stuck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kblank05 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2010 at 6:46pm
great ideas, i was counterplating on pulling the cover off....  let me try that and ill get back with you all. thanks!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote kblank05 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2010 at 6:55pm
valves are not stuck.... still confusing...
Tony Elo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Elo Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2010 at 7:03pm
did you check the valve clearances?
Post Options Post Options   Thanks (0) Thanks(0)   Quote kblank05 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2010 at 7:09pm
i just did that, AND the adjuster screw needed backed off a little bit got good comp. now!
THANKS EVERYONE!!!
