wc piston in 226 |
woody4178
Topic: wc piston in 226Posted: 28 Dec 2013 at 6:58pm |
I have a 226 4 1/8 bore 4.5 stroke out of a wd45 am wanting to put wc pistons in it I am tryin to avoid stroking it. Question is will this work,what are the wc pistons compression height and what kind of compressiom ratio/hp will I be getting. Fairly new to all this looking for advice.thanks
Kip-Utah
Joined: 14 Sep 2009 Location: Southern Utah Points: 921 |
Posted: 30 Dec 2013 at 1:21pm |
Yes you can run flat top WC or WD 4.125" replacement pistons with your combination. I'm running a similar combination but elected to go with 4.125" 170/175 crater pistons. We also used a WD45 block. This combo works out to be right at 240 cid and around 8.25:1 compression, and is good for about 58 hp at 2000 rpm. Depending which flat top pistons you use your compression ratio should be a little higher than ours. Kip
Edited by Kip-Utah - 30 Dec 2013 at 1:27pm |
woody4178
Posted: 30 Dec 2013 at 7:27pm |
Thanks kip pretty sure we are guna run wc flat tops 4.125 and s 170 cam
BennyLumpkin
Joined: 22 Mar 2010 Location: Centre Hall, PA Points: 2657 |
Posted: 30 Dec 2013 at 7:29pm |
Good luck finding a 170 cam....
Central PA Allis Express
1934 WC254 1945 WF 1945 WC135755 1951 WD68085 1953 WD45-150217 1957 WD45D-230744D B110 |
woody4178
Posted: 30 Dec 2013 at 8:31pm |
I did get lucky on the cam father in law hss one already to go
BennyLumpkin
Posted: 30 Dec 2013 at 8:53pm |
Very lucky
Bill_MN
Joined: 12 Sep 2009 Location: Sioux Falls, SD Points: 1471 |
Posted: 30 Dec 2013 at 10:43pm |
isn't it the 175 gas cam that's hard to find? or are they the same?
Posted: 31 Dec 2013 at 6:31am |
A 170 cam isn't any different grind than a D-17 or "E" Gleaner or WD45 or WC for that matter. The "175" camshaft is the special high lift grind.
dawntreader74
Posted: 18 Jan 2014 at 6:12pm |
SR' find you some small block chevy pistons with same rist pin holes. works fine.
bmartin55
Posted: 18 Jan 2014 at 7:06pm |
hi want to do same thing ..i have a 17 gleaner motor..need 4.125 pistons.want to grind crank& use 350 rods..OR 350 sbc pistons.. bob
Glockhead SWMI
Joined: 12 Sep 2009 Location: South West Mich Points: 2657 |
Posted: 21 Jan 2014 at 9:46am |
SBC 350 rods?
