WC oil pump gasket?
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: WC oil pump gasket?
    Posted: 25 Jan 2011 at 7:45pm
I'm wondering if an oil pump gasket comes with an overhaul set? I took the plate off and cleaned the oil pump and I want the right thickness gasket. I have to buy a complete gasket set anyway. Also will it have manifold gaskets?
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2011 at 8:11pm
my felpro complete set came with one
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2011 at 8:25pm
Be carefull when replacing that gasket as the one in the kits is often waaaay to thick leaving you to wonder why you have little oil pressure. Actualy if the pump is worn at all the best thing is to eliminate the gasket. Stone the surfaces flat. Bolt it together to make sure it doesnt bind then take it apart and use just a very small amount of silicone sealer under the cover. Yes the manifold gaskets will be in a complete OH kit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 4:04am
I put the plate back on after cleaning snugged the screws and it turns hard like it's dragging. Should I make one out of paper of some sort?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 5:41am
Realy? I have never run into one that unworn, well in the last 30 years anyway, LOL. First make sure you didn't flip the idler gear over, needs to go back the same way it came out and ck again. That not being the case it used to be available from AGCO as a seperate item. Ck there first. The paper should be so thin it is both delicate and  translucent.  The paper is available as sheet but making one wouldnt be fun times.
Edited by Butch(OH) - 26 Jan 2011 at 5:49am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2011 at 6:09am
Thanks for the help Butch. I'll check with agco on the gasket. I'll also remove the idler and put the cap back on and see what happens. The idler just wanted to go on one way when I put it back together.
This page was generated in 1.281 seconds.
