WC oil leak |
jshoemaker
Topic: WC oil leakPosted: 10 May 2011 at 9:31am |
The plate on the side of my WC engine block leaks oil a bit. I put a new gasket on it, gaskets epoxy, etc... and it still leaks. The bolts seem to work themselves loose over time as well, so I tighten them as need be. I hear this is a common problem with the WC, any suggestions?
1948 WC
Alberta Phil
Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3985 |
Posted: 10 May 2011 at 9:42am |
Some of the leakage is from around the bolts. Copper or fibre washers under the bolt heads seems to help.
Gary in Texas
Joined: 11 Sep 2009 Location: Burkburnett, TX Points: 630 |
Posted: 10 May 2011 at 10:33am |
On my WC and WD I used Indian Head gasket cement to stick the gasket to the plate, cleaned the side of the block with lacquer thiner, let it dry good, then a thin coating of red high temp RTV around the edge of the block and around the bolt holes. That seems to have my leak problem taken care of.
