WC Brake Drum Question
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Topic: WC Brake Drum Question
    Posted: 17 Mar 2010 at 10:22am
  I have been trying to remove a brake drum from the pinion shaft on my WC without breaking it and not having much luck. Other side slid right off. This side that I'm fighting with has been heated and cooled repeatedly, with liberal soakings with loose juice. Might be easier to bust /break this drum intopeices and replace it . Looking for advice , and/ or a good used drum. Thanks, Gary
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2010 at 11:29am
Remember that heat (expands) and cooling (shrinks).
Keep it hot hot while trying to slide it off. Also when the pinion shaft heats up it expands as well. That means quick heat on the drum and start it moving before the heat sinks into the shaft.
