Wartime WC's
Message Reverse Sort Order
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Topic: Wartime WC's
    Posted: 09 Mar 2011 at 9:13am
During WWII we were lucky to get whatever tractors we could.  Yes, in 1944 there were steel rear ends on the WC's and that carried through till the inventory of steel rears was ended.  Could have been 1946 - perhaps early 1947.
Remember, we were fighting a demanding war with many government priorities.  Frankly, we were very happy to get ANYTHING NEW!  We got cast iron valve covers, cast iron oil pans, and steel rear ends.  Steel all four wheels, Steel rear wheels with rubber front.  Didn't matter it was a new tractor and we were delighted to get it.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2011 at 12:26am
Chris I wonder how this one got out the door.
WC 163161S 1947 resides in the South Island of New Zealand, posted by Orange Kiwi
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2011 at 12:23am
Were the cast iron oil pan, valve cover and final drive covers on the B/C models during the war? I assumed they were but that doesn't make sense if they replaced steel with cast on one model and replaced cast with steel on another.
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2011 at 10:37pm
How did some 45 model year tractors end up with steel rears, and others with cast?
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Brian Ahart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Ahart Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2011 at 10:27pm
A-C Weight ID reference and other goodies at brianahart.net
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2011 at 9:43pm
Have a 46' WC with steel rear end.
Wink
I am a Russian Bot
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2011 at 9:40pm
1942 starting #114534, 1945 ending #140090.HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2011 at 9:38pm
I have a book here that has the production numbers from start to finish.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2011 at 9:37pm
One of my books shows serial # 127642 starting in 1944. 1933 started WC1 thru WC 28.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2011 at 9:36pm
Not so much years as the ones with the steel rearendsinstead of cast.  As far as I know, no one really has any official production numbers.  I'm thinking around 42-45, the serial number ends with an "S".
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2011 at 9:34pm
They were supposedly started in 1944 at about serial #132005 but not sure when they ended. There was discussion a while back about who had the highest steel rearend serial #.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2011 at 9:26pm
Which years are the wartimes?
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2011 at 9:23pm
Does anybody know when they started and ended the run of these tractors? What is the lowest and highest S.N. known?
