*volt Battery in a 6 volt system, 1958 D-14
tominMi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tominMi Quote  Post ReplyReply Direct Link To This Post Topic: *volt Battery in a 6 volt system, 1958 D-14
    Posted: 01 Sep 2011 at 9:29am
I experienced low charge & no starting on my recently purchased D-14. Had the battery tested at local NAPA store. Test shows a dead cell. Also found that the battery is an 8 volt. There was no date of sale indicated on the battery so have no idea of age or how long it has been in the tractor.  My questions are: will an 8 volt battery harm a 6 volt electrical system? Will a bad cell prevent a battery from accepting and maintaining a full charge?
Steve M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 9:42am
A 6 volt electrical system won't charge a 8 volt battery.  I would go with a good 6 volt battery and make sure your starter and charging system are in good working order. On a 6 volt system its important to have the right size battery cable and make sure they are getting a good connection.
Creek Jenkins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2011 at 10:09am
I use an 8 volt on my G with no problems.  Charges and starts fine all summer, the 8 volt gives it a little extra kick over, she starts usually in the first few turns.  I put the trickle charger on it once or twice over the winter as it doesn't get run at all.  In the summer I do a lot of start up and run for less than 10 minutes as my rellies and friends like to see it run and take it for a short drive.  I try to run it for at least 30 minutes as often as I can to keep the moisture out of the engine and the battery charged.  Never have had the battery go deed, the generator charges it fine.
I think if you have one cell shorted out it will drain the others.  Depends on the type of failure in that cell, I think anyway.  I recently had a brand new 12v battery in my C that went bad in two weeks - low voltage, wouldn't take a charge and not enough power wouldn't turn the engine.  Finally figured out it was the battery, took it back, got a new one, end of problem.
cheers,
Creek
This page was generated in 1.531 seconds.
