Using Starting Fluid |
WNYBill
Topic: Using Starting FluidPosted: 30 Nov 2016 at 7:58am |
Just read the thread on mixing diesel and gasoline, NO NO!
My 6060 has a factory installed ether injector. It starts hard, my understanding is designed low compression. I crank for 10-15 seconds, let it rest and crank again until there is lots of white smoke. Then I touch the button and usually it starts with no knock. Sometimes takes a second touch. I said touch, not push and hold. It does not knock like the Ford or IH did. What is the proper procedure so as not to damage the engine? Bill
Posted: 30 Nov 2016 at 8:36am |
On that electric ether system, the ether is released only when you let go of the button. The ether button only works when the starter button is engaged (if it's wired correctly). On a personal note, every 6000 series that I ever pre-delivered (40 or 50 of them) always had the ether injector nozzle relocated to the air tube above the air cleaner and ahead of the turbocharger. This allowed the ether to enter the engine with a lot less "bang", versus the intake manifold location. I would drill a hole in the air tube and braze/weld a 1/8" pipe thread coupler to the tube and move the ether nozzle. Worked very well and easier on the engine in my opinion.
Brian Jasper co. Ia
Thanks(1)
Posted: 30 Nov 2016 at 8:38am |
Sounds like you're doing it right. When its cold outside I basically do the same thing on my D17D. I crank long enough to get oil pressure and plenty of smoke. Then a 1/4 to 1/2 second whiff at most through the intake hole and she fires right up with no knocking either.
DanD
Posted: 30 Nov 2016 at 3:02pm |
Pretty much use the same method for starting my dad's F3 Gleaner. However if we plug the block heater in even for just an hour or so before we know we'll start it, it starts just like it's July with no ether.
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55276 |
Posted: 30 Nov 2016 at 6:19pm |
I hadda D-19 that learned how to push its own ether button...
DougG
Posted: 30 Nov 2016 at 6:40pm |
Put some John Deere 80% in there and yeah it,ll come to life ! That stuff will make em knock , the cheap stuff is not as bad , Dr Allis is right on with moving it in the tube
Johnwilson_osf
Joined: 29 Jul 2012 Location: Mount Bethel PA Points: 944 |
Posted: 30 Nov 2016 at 8:16pm |
Was at an auction last week, and there was a JD 4010 sitting there. It was a cold morning, and she wouldn't start. The "Mechanics" tried to give it some ether to start. Put in so much, it blew the top end out. I don't think that the machine brought what they were expecting at the beginning of the auction.
John |
Allis Express: Eastern PA on Rt 80
8050, 8010, 6080, 190, D14, DA 6035, AA 6690, 5650, Gleaner F2 |
victoryallis
Joined: 15 Apr 2010 Location: Ludington mi Points: 2887 |
Posted: 30 Nov 2016 at 8:30pm |
Why are you using starting fluid at all anyway? I have had one 6080 for 17 years so far the other for 11 or 12 so far so basically 28 to 30 years in that time I bet total I havnt used starting fluid 5 times on them may occasionally use the manifold heater but that's it. Thinking about it the starting fluid option doesn't work on any of our tractors.
MACK
Posted: 30 Nov 2016 at 9:25pm |
What do you mean on the
4010? (blew the top end out) ? MACK
Posted: 30 Nov 2016 at 11:06pm |
VictoryAllis....your tractors apparently are newer than the oldest 14 to 1 compression ratio tractors. They usually needed some sort of help on a cold start-up.
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12418 |
Posted: 01 Dec 2016 at 8:02am |
I'm with victoryallis, almost never use starting fluid. The machines I have with a starting fluid injector....I don't know if any of them work, never used them. I DO, religiously, use block heaters. My tractor that gets used for feeding all winter, I put a Christmas tree light timer on the block heater, set to come on about 2 hours before chore time, and turns itself off.
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3131 |
Posted: 01 Dec 2016 at 9:33am |
I think the starting fluid problem is being a little exaggerated here. It may not be the best, but it's been used on our farm for years with no issues. We still plug in block heaters when possible but it isn't always.
One old Detroit Diesel grain truck doesn't have a heater and won't start at 40 degrees. One of the 4WD's on the grain cart won't start below 40 without a little ether. Where do you plug in the heater when out on a remote farm? Without a little ether I guess I'd have to drive it 30 minutes home each night or spend 10k to rebuild a tractor that otherwise runs well. I spray a little in the intake. Don't hardly ever inject it anywhere. Edited by Allis dave - 01 Dec 2016 at 9:36am |
ACFarmer
Posted: 01 Dec 2016 at 9:58am |
Always been my thoughts that if you had trouble using ether, you weren't using it right to begin with.
Making a living farming with and working on Allis Equipment
Butch(OH)
Posted: 01 Dec 2016 at 10:09am |
Ya think??? ![]() Here and anywhere else the subject comes up,,,, |
Tbone95
Posted: 01 Dec 2016 at 10:40am |
Well I for one don't have a "problem" with it at all. The times I need it, like remote as stated, I use it without a second thought. Just the way I do things, I guess I very rarely need it and I like it that way.
Brian Jasper co. Ia
Posted: 01 Dec 2016 at 12:01pm |
Not a thing wrong with keeping them warm. I mostly keep my D17D in the heated shop. Ether gets a bad rap because some people think if a little is good, a lot must be better. Before I had heat in the shop that 1/4-1/2 second whiff was just right to get it started unless it was like -10. It lights right off on the whiff, but usually die right away. another 1/4-1/2 second whiff and it would have enough heat built up to keep running.
Johnwilson_osf
Posted: 01 Dec 2016 at 1:02pm |
Mack,
The head gasket blew out... |
Dgrader
Joined: 17 Jan 2015 Location: Newton,IL Points: 1037 |
Posted: 01 Dec 2016 at 1:10pm |
I use ether all the time. No problems. It's like a lot of things, use a little common sense. Something a lot of people have a problem with. If ya don't know how to use it, probly better stay away from it. I'd say that's why so many like to bash it. They just need educated.
Ya cain't fix stupid.
victoryallis
Posted: 01 Dec 2016 at 1:30pm |
One 6080 was 14 to 1 had electrolysis so once it was rebuilt it became 16 to 1. If they need starting fluid they needed to be plugged in. |
Posted: 01 Dec 2016 at 1:44pm |
There is night-and-day difference between the 14 and 16 to 1 engines when it comes to cold-starts.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42266 |
Posted: 01 Dec 2016 at 2:04pm |
Adding it as the engine is turning and in just a slight wiff - not the lets spray a 1/4 can into intake then turn it over and add another 1/4 can - OOPS it either locked now - didn't need it running anyway - wait till tomorrow and plug it in to make sure it will start next time
