Un-styled WC
David Terry View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Terry Quote  Post ReplyReply Direct Link To This Post Topic: Un-styled WC
    Posted: 28 Feb 2015 at 6:22am
Does anyone know if you can put a D17 Series III in to an Un-styled WC chassis? I can get a rebuilt motor and that would be easier than trying to rebuild an old gleaner I have. Thanks, Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2015 at 6:58am
Any D-17 gas engine can be made fit into a WC tractor. Use the WC flywheel and clutch, water pump and crankshaft pulley( bore the pulley for a thru hole). The one oil line from the filter base to the block may have to be repositioned to clear the steering wheel shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Terry Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2015 at 7:21am
Dr. Allis,
I am on the cusp of going for it. I have a gleaner engine, but it isn't complete and I'd have just about as much in the gleaner as I would buying the rebuilt D17.
Dave
cotncrzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2015 at 7:32am
I have a Nice one built up for sale, sitting in a crate ready to go! Custom cam, flat tops, all the modifications have been made. Literally ready to bolt in and crank. Has about 5to 10 hours on it. STRONG ENGINE!
Edited by cotncrzy - 01 Mar 2015 at 7:36am
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
This page was generated in 0.551 seconds.
